Phantomas: a flexible software library to simulate diffusion MR phantoms - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We introduce Phantomαs, an open-source software library to create realistic phantoms in structural and diffusion MRI. This is intended as a tool for researchers working in method development or translational research in the field of diffusion-weighted MRI. The software allows evaluation of the whole tractography processing pipeline: acquisition design, preprocessing, local reconstruction and tractography algorithm.
caruyer-daducci-etal-ismrm14.pdf (1.69 Mo) Télécharger le fichier
hal-00944644 , version 1 (10-02-2014)
  • HAL Id : hal-00944644 , version 1
Emmanuel Caruyer, Alessandro Daducci, Maxime Descoteaux, Jean-Christophe Houde, Jean-Philippe Thiran, et al.. Phantomas: a flexible software library to simulate diffusion MR phantoms. ISMRM, May 2014, Milan, Italy. ⟨hal-00944644⟩
411 Consultations
639 Téléchargements
