Fast and stable YAST algorithm for principal and minor subspace tracking - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE_J_SP Année : 2008
This paper presents a new implementation of the YAST algorithm for principal and minor subspace tracking. YAST was initially derived from the Subspace Projection (SP) algorithm by C.E. Davila, which was known for its exceptional convergence rate, compared to other classical principal subspace trackers. The novelty in the YAST algorithm was the lower computational cost (linear if the data correlation matrix satisfies a so-called shift-invariance property), and the extension to minor subspace tracking. However, the original implementation of the YAST algorithm suffered from a numerical stability problem (the subspace weighting matrix slowly loses its orthonormality). We thus propose in this paper a new implementation of YAST, whose stability is established theoretically and tested via numerical simulations. This algorithm combines all the desired properties for a subspace tracker: remarkably high convergence rate, lowest steady state error, linear complexity, and numerical stability regarding the orthonormality of the subspace weighting matrix.
ieee-tsp-08b.pdf (410.76 Ko) Télécharger le fichier
hal-00945194 , version 1 (24-03-2014)
  • HAL Id : hal-00945194 , version 1
Roland Badeau, Gael Richard, Bertrand David. Fast and stable YAST algorithm for principal and minor subspace tracking. IEEE_J_SP, 2008, 56 (8), pp.3437--3446. ⟨hal-00945194⟩
409 Consultations
446 Téléchargements
