Beta-divergence as a subclass of Bregman divergence - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Signal Processing Letters Année : 2011
In this paper, we present a complete proof that the beta-divergence is a particular case of Bregman divergence. This little-known result makes it possible to straightforwardly apply theorems about Bregman divergences to beta-divergences. This is of interest for numerous applications since these divergences are widely used, for instance in non-negative matrix factorization (NMF).
Hennequin-SPL2011.pdf (79.41 Ko) Télécharger le fichier
hal-00945202 , version 1 (25-03-2014)
  • HAL Id : hal-00945202 , version 1
Romain Hennequin, Bertrand David, Roland Badeau. Beta-divergence as a subclass of Bregman divergence. IEEE Signal Processing Letters, 2011, 18 (2), pp.83--86. ⟨hal-00945202⟩
316 Consultations
936 Téléchargements
