Sliding Window Orthonormal PAST Algorithm - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2003
This paper introduces an orthonormal version of the sliding-window Projection Approximation Subspace Tracker (PAST). The new algorithm guarantees the orthonormality of the signal subspace basis at each iteration. Moreover, it has the same complexity as the original PAST algorithm, and like the more computationally demanding natural power (NP) method, it satisfies a global convergence property, and reaches an excellent tracking performance.
icassp-03-bis.pdf (102.18 Ko) Télécharger le fichier
hal-00945271 , version 1 (24-03-2014)
  • HAL Id : hal-00945271 , version 1
Roland Badeau, Karim Abed-Meraim, Gael Richard, Bertrand David. Sliding Window Orthonormal PAST Algorithm. Proc. of IEEE International Conference on Acoustics, Speech, and Signal Processing (ICASSP), 2003, Hong Kong, China. pp.261--264. ⟨hal-00945271⟩
269 Consultations
355 Téléchargements
