Grasping objects with a cable-driven parallel robot designed for transfer operation by visual servoing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Our objective is to extend the assistance function- alities of the cable-driven parallel robot Marionet-Assist, designed principally for transfer operation, by allowing it to grasp usual objects (knives, box of medicines, phone, ***) by using visual servoing. Our crane robot has a configuration that provides three translational d.o.f., and a camera was added to its end-effector. In order to compute the translational velocity sent to the robot controller, the area and center of gravity in the image of the object to be grasped are used. Experimental results are presented. They show the robustness of our scheme with respect to modeling errors and an excellent positioning accuracy allowing grasping.
2014_icra_ramadour.pdf (476.75 Ko) Télécharger le fichier
hal-00949346 , version 1 (19-02-2014)
  • HAL Id : hal-00949346 , version 1
Remi Ramadour, François Chaumette, Jean-Pierre Merlet. Grasping objects with a cable-driven parallel robot designed for transfer operation by visual servoing. IEEE Int. Conf. on Robotics and Automation, ICRA'14, Jun 2014, Hong-Kong, Hong Kong SAR China. ⟨hal-00949346⟩
325 Consultations
436 Téléchargements
