Spline Spaces over Quadrangle Meshes with Complex Topologies - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2014
Meng Wu
  • Fonction : Auteur
  • PersonId : 953441
Bernard Mourrain
André Galligo
  • Fonction : Auteur
  • PersonId : 835184
We present a new type of spline functions defined over a quadrangular mesh equipped with an equivalence relation, in such a way that physical spaces with a complex topology can be represented as an homomorphic image of such meshes. We provide general definitions, a dimension formula for a subclass of these spline spaces, an explicit construction of their bases and also a process for local refinement. These developments, motivated by plane curvilinear mesh constructions are illustrated on several parametrization problems. Our main target in these constructions is to approximate isobaric lines of magnetic fields encountered in MHD simulation for Tokamaks. Their particularity is that one of the isobaric curve has a node singularity.
paper.pdf (740.45 Ko) Télécharger le fichier
hal-00952455 , version 1 (28-02-2014)
  • HAL Id : hal-00952455 , version 1
Meng Wu, Bernard Mourrain, André Galligo, Boniface Nkonga. Spline Spaces over Quadrangle Meshes with Complex Topologies. 2014. ⟨hal-00952455⟩
231 Consultations
205 Téléchargements
