Using Cliques of Nodes to Store Desktop Grid Checkpoints - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
Checkpoints that store intermediate results of computation have a fundamental impact on the computing throughput of Desktop Grid systems, like BOINC. Currently, BOINC workers store their checkpoints locally. A major limitation of this approach is that whenever a worker leaves unfinished computation, no other worker can proceed from the last stable checkpoint. This forces tasks to be restarted from scratch when the original machine is no longer available. To overcome this limitation, we propose to share checkpoints between nodes. To organize this mechanism, we arrange nodes to form complete graphs (cliques), where nodes share all the checkpoints they compute. Cliques function as survivable units, where checkpoints and tasks are not lost as long as one of the nodes of the clique remains alive. To simplify construction and maintenance of the cliques, we take advantage of the central supervisor of BOINC. To evaluate our solution, we combine simulation with some real data to answer the most fundamental question: what do we need to pay for increased throughput?
araujo_coregrid08.pdf (911.12 Ko) Télécharger le fichier
hal-00953613 , version 1 (10-03-2014)
  • HAL Id : hal-00953613 , version 1
Filipe Araujo, Patricio Domingues, Derrick Kondo, Luis Moura Silva. Using Cliques of Nodes to Store Desktop Grid Checkpoints. Coregrid Integration Workshop, 2008, Crete, Greece. ⟨hal-00953613⟩
196 Consultations
156 Téléchargements
