Evaluation of Multi-Agent Systems: The case of Interaction - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
This paper deals with the evaluation of Multi-Agent Systems (MAS) at the level of their interaction. Two problems that may be a bias in the evaluation and measurement of interaction are discussed. The first one is the difference between the quantities of information carried by a unit of interaction in two systems having different architectures. The second one concerns the interaction units that are received and cannot be exploited by the agent. In this work, an evaluation based on the weight of the information brought by an interaction is suggested. In order to achieve this, a MAS model, on which the evaluation is based, is defined. Then, the different problems and solutions which will help to evaluate the interaction are studied. Finally, the approach is applied on two different implementations that solve the same problem.
ICTTA-2008.pdf (134.39 Ko) Télécharger le fichier
hal-00953626 , version 1 (28-02-2014)
  • HAL Id : hal-00953626 , version 1
Hussein Joumaa, Yves Demazeau, Jean-Marc Vincent. Evaluation of Multi-Agent Systems: The case of Interaction. Proceedings of the 3rd International Conference on Information & Communication Technologies: from Theory to Applications (ICTTA'08), 2008, Damascus, Syria. ⟨hal-00953626⟩
171 Consultations
210 Téléchargements
