Types for Deadlock-Free Higher-Order Concurrent Programs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2014
Luca Novara
  • Fonction : Auteur
  • PersonId : 953465
Deadlock freedom is for concurrent programs what progress is for sequential ones: it indicates the absence of stable (i.e., irreducible) states in which some pending operations cannot be completed. In the particular case of communicating processes, operations are inputs and outputs on channels and deadlocks may be caused by mutual dependencies between communications. In this work we define an effect system ensuring deadlock freedom of higher-order programs that communicate over linear channels and study its integration with polymorphic and recursive types.
PadovaniNovara14.pdf (337.15 Ko) Télécharger le fichier
hal-00954364 , version 1 (01-03-2014)
  • HAL Id : hal-00954364 , version 1
Luca Padovani, Luca Novara. Types for Deadlock-Free Higher-Order Concurrent Programs. 2014. ⟨hal-00954364⟩
135 Consultations
166 Téléchargements
