A delay-based routing metric - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2015
Baptiste Jonglez
In overlay networks, both local and long-distance links appear as a single hop to a routing protocol, and traditional routing metrics (based on hop count or packet loss) fail to take the differences between such links into account. In this paper, we describe the design and implementation of a metric based on packet delay that is designed to improve routing in overlay networks. Using delay naively leads to persistent routing oscillations, but the Babel routing protocol within which our metric is implemented employs a number of features to bound the frequency of oscillations and limit their impact by ensuring consistency even during reconvergence. We show experimental data that indicate that the protocol causes no oscillations in real-world situations, and has oscillations with a period on the order of minutes in artificially constructed topologies.
delay-based.pdf (272.53 Ko) Télécharger le fichier
hal-00954373 , version 1 (13-03-2014)
hal-00954373 , version 2 (26-03-2015)
Baptiste Jonglez, Matthieu Boutier, Juliusz Chroboczek. A delay-based routing metric. 2015. ⟨hal-00954373v2⟩
203 Consultations
130 Téléchargements
