E-unification by means of tree tuple synchronized grammars - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Mathematics and Theoretical Computer Science Année : 1997
The goal of this paper is both to give an E-unification procedure that always terminates, and to decide unifiability. For this, we assume that the equational theory is specified by a confluent and constructor-based rewrite system, and that four additional restrictions are satisfied. We give a procedure that represents the (possibly infinite) set of solutions thanks to a tree tuple synchronized grammar, and that can decide upon unifiability thanks to an emptiness test. Moreover, we show that if only three of the four additional restrictions are satisfied then unifiability is undecidable.
dm010105.pdf (413.56 Ko) Télécharger le fichier
hal-00955691 , version 1 (05-03-2014)
Sébastien Limet, Pierre Réty. E-unification by means of tree tuple synchronized grammars. Discrete Mathematics and Theoretical Computer Science, 1997, Vol. 1, pp.69-98. ⟨10.46298/dmtcs.240⟩. ⟨hal-00955691⟩
92 Consultations
726 Téléchargements
