Generating Tests from B Specifications and Dynamic Selection Criteria - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Formal Aspects of Computing Année : 2011
This paper is about generating tests from dynamic selection criteria called test purposes, in addition to structural tests, obtained from static selection criteria. We present a method that re-uses a behavioral model and an abstract test concretization layer developed for structural testing, and relies on additional test purposes. We propose, in the B framework, a process of test generation that uses the symbolic animation mechanisms of LTG (Leirios Test Generator) based on constraint solving, and guided by the test purposes. We build for that a B model that is the synchronized product of a behavioral B abstract model and a test purpose described as a labelled transition system. We prove the correctness of this method, and show some experimental results obtained on the IAS case study. IAS is an industrial smart-card platform dedicated to the operations of Identification, Authentication and electronic Signature. Our experiments show that the tests obtained from test purposes are complementary to the structural tests.
jmtb11_ij-author.pdf (609.72 Ko) Télécharger le fichier
hal-00956576 , version 1 (06-03-2014)
  • HAL Id : hal-00956576 , version 1
Jacques Julliand, Pierre-Alain Masson, Régis Tissot, Pierre-Christophe Bué. Generating Tests from B Specifications and Dynamic Selection Criteria. Formal Aspects of Computing, 2011, 23, pp.3 - 19. ⟨hal-00956576⟩
30 Consultations
42 Téléchargements
