Quicksort algorithm again revisited - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Mathematics and Theoretical Computer Science Année : 1999
We consider the standard Quicksort algorithm that sorts n distinct keys with all possible n! orderings of keys being equally likely. Equivalently, we analyze the total path length L(n) in a randomly built \emphbinary search tree. Obtaining the limiting distribution of L(n) is still an outstanding open problem. In this paper, we establish an integral equation for the probability density of the number of comparisons L(n). Then, we investigate the large deviations of L(n). We shall show that the left tail of the limiting distribution is much ''thinner'' (i.e., double exponential) than the right tail (which is only exponential). Our results contain some constants that must be determined numerically. We use formal asymptotic methods of applied mathematics such as the WKB method and matched asymptotics.
dm030202.pdf (187.84 Ko) Télécharger le fichier
hal-00958926 , version 1 (13-03-2014)
Charles Knessl, Wojciech Szpankowski. Quicksort algorithm again revisited. Discrete Mathematics and Theoretical Computer Science, 1999, Vol. 3 no. 2 (2), pp.43-64. ⟨10.46298/dmtcs.252⟩. ⟨hal-00958926⟩
Collections
TDS-MACS
78 Consultations
1011 Téléchargements
