Paths of specified length in random k-partite graphs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Mathematics and Theoretical Computer Science Année : 2001
Fix positive integers k and l. Consider a random k-partite graph on n vertices obtained by partitioning the vertex set into V_i, (i=1, \ldots,k) each having size Ω (n) and choosing each possible edge with probability p. Consider any vertex x in any V_i and any vertex y. We show that the expected number of simple paths of even length l between x and y differ significantly depending on whether y belongs to the same V_i (as x does) or not. A similar phenomenon occurs when l is odd. This result holds even when k,l vary slowly with n. This fact has implications to coloring random graphs. The proof is based on establishing bijections between sets of paths.
dm040206.pdf (39.14 Ko) Télécharger le fichier
hal-00958953 , version 1 (13-03-2014)
C.R. Subramanian. Paths of specified length in random k-partite graphs. Discrete Mathematics and Theoretical Computer Science, 2001, Vol. 4 no. 2 (2), pp.133-138. ⟨10.46298/dmtcs.286⟩. ⟨hal-00958953⟩
Collections
TDS-MACS
46 Consultations
678 Téléchargements
