Statistical properties of general Markov dynamical sources: applications to information theory - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Mathematics and Theoretical Computer Science Année : 2004
In \textitDynamical sources in information theory: fundamental intervals and word prefixes, B. Vallée studies statistical properties of words generated by dynamical sources. This is done using generalized Ruelle operators. The aim of this article is to generalize sources for which the results hold. First, we avoid the use of Grotendieck theory and Fredholm determinants, this allows dynamical sources that cannot be extended to a complex disk or that are not analytic. Second, we consider Markov sources: the language generated by the source over an alphabet \textbfM is not necessarily \textbfM^*.
dm060208.pdf (229.25 Ko) Télécharger le fichier
hal-00959009 , version 1 (13-03-2014)
Frédéric Chazal, Véronique Maume-Deschamps. Statistical properties of general Markov dynamical sources: applications to information theory. Discrete Mathematics and Theoretical Computer Science, 2004, Vol. 6 no. 2 (2), pp.283-314. ⟨10.46298/dmtcs.329⟩. ⟨hal-00959009⟩
120 Consultations
715 Téléchargements
