Separation of Music+Effects sound track from several international versions of the same movie - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Antoine Liutkus
Pierre Leveau
  • Fonction : Auteur
  • PersonId : 953899
This article concerns the separation of the music+effects (ME) track from a movie sountrack, given the observation of several international versions of the same movie. The approach chosen is strongly inspired from existing stereo audio source separation and especially from spatial filtering algorithms such as DUET that can extract a constant panned source from a mixture very efficiently. The problem is indeed similar for we aim here at separating the ME track, which is the common background of all international versions of the movie soundtrack. The algorithm has been adapted to a number of channels greater than 2. Preprocessing techniques have also been proposed to adapt the algorithm to realistic cases. The performances of the algorithm have been evaluated on realistic and synthetic cases.
liutkus_MESeparation.pdf (1017.31 Ko) Télécharger le fichier
hal-00959108 , version 1 (14-03-2014)
  • HAL Id : hal-00959108 , version 1
Antoine Liutkus, Pierre Leveau. Separation of Music+Effects sound track from several international versions of the same movie. AES 128th Convention, May 2010, London, United Kingdom. ⟨hal-00959108⟩
276 Consultations
397 Téléchargements
