Nonparametric estimation of the conditional tail copula - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Multivariate Analysis Année : 2015
The tail copula is widely used to describe the dependence in the tail of multivariate distributions. In some situations such as risk management, the dependence structure may be linked with some covariate. The tail copula thus depends on this covariate and is referred to as the conditional tail copula. The aim of this paper is to propose a nonparametric estimator of the conditional tail copula and to establish its asymptotic normality. Some illustrations are presented both on simulated and real datasets.
CTDC16.pdf (784.14 Ko) Télécharger le fichier
hal-00964514 , version 1 (24-03-2014)
hal-00964514 , version 2 (16-09-2014)
hal-00964514 , version 3 (20-01-2015)
Laurent Gardes, Stéphane Girard. Nonparametric estimation of the conditional tail copula. Journal of Multivariate Analysis, 2015, 137, pp.1-16. ⟨10.1016/j.jmva.2015.01.018⟩. ⟨hal-00964514v3⟩
691 Consultations
501 Téléchargements
