Resources Description, Selection, Reservation and Verification on a Large-scale Testbed - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The management of resources on testbeds, including their description, reservation and verification, is a challenging issue, especially on of large scale testbeds such as those used for research on High Performance Computing or Clouds. In this paper, we present the solution designed for the Grid'5000 testbed in order to: (1) provide users with an in-depth and machine-parsable description of the testbed's resources; (2) enable multi-criteria selection and reservation of resources using a HPC resource manager; (3) ensure that the description of the resources remains accurate.
g5kresources.pdf (309.23 Ko) Télécharger le fichier
hal-00965708 , version 1 (25-03-2014)
hal-00965708 , version 2 (23-06-2014)
  • HAL Id : hal-00965708 , version 1
David Margery, Emile Morel, Lucas Nussbaum, Olivier Richard, Cyril Rohr. Resources Description, Selection, Reservation and Verification on a Large-scale Testbed. TRIDENTCOM - 9th International Conference on Testbeds and Research Infrastructures for the Development of Networks & Communities, May 2014, Guangzhou, China. ⟨hal-00965708v1⟩
834 Consultations
663 Téléchargements
