Clique cycle transversals in graphs with few P₄'s - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Mathematics and Theoretical Computer Science Année : 2013
A graph is extended P4-laden if each of its induced subgraphs with at most six vertices that contains more than two induced P4's is 2K2,C4-free. A cycle transversal (or feedback vertex set) of a graph G is a subset T ⊆ V (G) such that T ∩ V (C) 6= ∅ for every cycle C of G; if, in addition, T is a clique, then T is a clique cycle transversal (cct). Finding a cct in a graph G is equivalent to partitioning V (G) into subsets C and F such that C induces a complete subgraph and F an acyclic subgraph. This work considers the problem of characterizing extended P4-laden graphs admitting a cct. We characterize such graphs by means of a finite family of forbidden induced subgraphs, and present a linear-time algorithm to recognize them.
2309-8345-1-PB.pdf (106.82 Ko) Télécharger le fichier
hal-00966377 , version 1 (26-03-2014)
Raquel Bravo, Sulamita Klein, Loana Tito Nogueira, Fábio Protti. Clique cycle transversals in graphs with few P₄'s. Discrete Mathematics and Theoretical Computer Science, 2013, Vol. 15 no. 3 (3), pp.13--20. ⟨10.46298/dmtcs.616⟩. ⟨hal-00966377⟩
Collections
TDS-MACS
132 Consultations
1340 Téléchargements
