Surjective cellular automata far from the Garden of Eden - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Mathematics and Theoretical Computer Science Année : 2013
Silvio Capobianco
  • Fonction : Auteur
  • PersonId : 884133
Jarkko Kari
One of the first and most famous results of cellular automata theory, Moore's Garden-of-Eden theorem has been proven to hold if and only if the underlying group possesses the measure-theoretic properties suggested by von Neumann to be the obstacle to the Banach-Tarski paradox. We show that several other results from the literature, already known to characterize surjective cellular automata in dimension d, hold precisely when the Garden-of-Eden theorem does. We focus in particular on the balancedness theorem, which has been proven by Bartholdi to fail on amenable groups, and we measure the amount of such failure.
2336-8374-1-PB.pdf (259.24 Ko) Télécharger le fichier
hal-00966380 , version 1 (26-03-2014)
Silvio Capobianco, Pierre Guillon, Jarkko Kari. Surjective cellular automata far from the Garden of Eden. Discrete Mathematics and Theoretical Computer Science, 2013, Vol. 15 no. 3 (3), pp.41--60. ⟨10.46298/dmtcs.618⟩. ⟨hal-00966380⟩
399 Consultations
1087 Téléchargements
