Approximation and inapproximability results on balanced connected partitions of graphs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Mathematics and Theoretical Computer Science Année : 2007
Let G=(V,E) be a connected graph with a weight function w: V \to \mathbbZ₊, and let q ≥q 2 be a positive integer. For X⊆ V, let w(X) denote the sum of the weights of the vertices in X. We consider the following problem on G: find a q-partition P=(V₁,V₂, \ldots, V_q) of V such that G[V_i] is connected (1≤q i≤q q) and P maximizes \rm min\w(V_i): 1≤q i≤q q\. This problem is called \textitMax Balanced Connected q-Partition and is denoted by BCP_q. We show that for q≥q 2 the problem BCP_q is NP-hard in the strong sense, even on q-connected graphs, and therefore does not admit a FPTAS, unless \rm P=\rm NP. We also show another inapproximability result for BCP₂ on arbitrary graphs. On q-connected graphs, for q=2 the best result is a \frac43-approximation algorithm obtained by Chleb\'ıková; for q=3 and q=4 we present 2-approximation algorithms. When q is not fixed (it is part of the instance), the corresponding problem is called \textitMax Balanced Connected Partition, and denoted as BCP. We show that BCP does not admit an approximation algorithm with ratio smaller than 6/5, unless \rm P=\rm NP.
656-2516-1-PB.pdf (218.49 Ko) Télécharger le fichier
hal-00966506 , version 1 (26-03-2014)
Frédéric Chataigner, Liliane R. B. Salgado, Yoshiko Wakabayashi. Approximation and inapproximability results on balanced connected partitions of graphs. Discrete Mathematics and Theoretical Computer Science, 2007, Vol. 9 no. 1 (1), pp.177--192. ⟨10.46298/dmtcs.384⟩. ⟨hal-00966506⟩
Collections
TDS-MACS
156 Consultations
1252 Téléchargements
