Isogeny graphs with maximal real multiplication - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2015
An isogeny graph is a graph whose vertices are principally polarized abelian varieties and whose edges are isogenies between these varieties. In his thesis, Kohel described the structure of isogeny graphs for elliptic curves and showed that one may compute the endomorphism ring of an elliptic curve defined over a finite field by using a depth first search algorithm in the graph. In dimension 2, the structure of isogeny graphs is less understood and existing algorithms for computing endomorphism rings are very expensive. Our setting considers genus 2 jacobians with complex multiplication, with the assumptions that the real multiplication subring is maximal and has class number one. We fully describe the isogeny graphs in that case. Over finite fields, we derive a depth first search algorithm for computing endomorphism rings locally at prime numbers, if the real multiplication is maximal. To the best of our knowledge, this is the first DFS-based algorithm in genus 2.
draft.pdf (830.27 Ko) Télécharger le fichier
hal-00967742 , version 1 (23-07-2014)
hal-00967742 , version 2 (19-06-2015)
hal-00967742 , version 3 (17-10-2016)
hal-00967742 , version 4 (23-02-2018)
hal-00967742 , version 5 (16-02-2019)
Sorina Ionica, Emmanuel Thomé. Isogeny graphs with maximal real multiplication. 2015. ⟨hal-00967742v3⟩
1093 Consultations
471 Téléchargements
