Using cascading Bloom filters to improve the memory usage for de Brujin graphs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Algorithms for Molecular Biology Année : 2014
Background
De Brujin graphs are widely used in bioinformatics for processing next-generation sequencing data. Due to a very large size of NGS datasets, it is essential to represent de Bruijn graphs compactly, and several approaches to this problem have been proposed recently.
Results
In this work, we show how to reduce the memory required by the data structure of Chikhi and Rizk (WABI'12) that represents de Brujin graphs using Bloom filters. Our method requires 30% to 40% less memory with respect to their method, with insignificant impact on construction time. At the same time, our experiments showed a better query time compared to the method of Chikhi and Rizk.
Conclusion
The proposed data structure constitutes, to our knowledge, currently the most efficient practical representation of de Bruijn graphs.
1748-7188-9-2.pdf (570.35 Ko) Télécharger le fichier
1748-7188-9-2.xml (102.31 Ko) Télécharger le fichier
Format : Autre
hal-00971576 , version 1 (03-04-2014)
Kamil Salikhov, Gustavo Sacomoto, Gregory Kucherov. Using cascading Bloom filters to improve the memory usage for de Brujin graphs. Algorithms for Molecular Biology, 2014, 9 (1), pp.2. ⟨10.1186/1748-7188-9-2⟩. ⟨hal-00971576⟩
250 Consultations
132 Téléchargements
