Using a Goal-Agenda and Committed Actions in Real-Time Planning - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In the context of real-time planning, this paper investigates the contributions of two enhancements for selecting actions. First, the agenda-driven planning enhancement ranks relevant atomic goals and solves them incrementally in a best-first manner. Second, the committed actions enhancement commits a sequence of actions to be executed at the following time steps. To assess these two enhancements, we developed a real-time planning algorithm in which action selection can be driven by a goal-agenda, and committed actions can be done. Experimental results, performed on classical planning prob- lems, show that agenda-planning and committed actions are clear advantages in the real-time context. Used simultaneously, they enable the planner to be several orders of magnitude faster and solution plans to be shorter.
pellier11f.pdf (128.02 Ko) Télécharger le fichier
hal-00972517 , version 1 (03-04-2014)
  • HAL Id : hal-00972517 , version 1
Damien Pellier, Bruno Bouzy, Marc Métivier. Using a Goal-Agenda and Committed Actions in Real-Time Planning. 23rd IEEE International Conference on Tools with Artificial Intelligence (ICTAI), Nov 2011, Boca Raton, United States. ⟨hal-00972517⟩
Collections
LIPADE UP-SCIENCES
84 Consultations
158 Téléchargements
