Hedging Algorithms and Repeated Matrix Games - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Playing repeated matrix games (RMG) while maximizing the cumulative returns is a basic method to evaluate multi-agent learning (MAL) algorithms. Previous work has shown that UCB, M3, S or Exp3 algorithms have good behaviors on average in RMG. Besides, hedging algorithms have been shown to be effective on prediction problems. An hedging algorithm is made up with a top-level algorithm and a set of basic algorithms. To make its decision, an hedging algorithm uses its top-level algorithm to choose a basic algorithm, and the chosen algorithm makes the decision. This paper experimentally shows that well-selected hedging algorithms are better on average than all previous MAL algorithms on the task of playing RMG against various players. S is a very good top-level algorithm, and UCB and M3 are very good basic algorithms. Furthermore, two-level hedging algorithms are more effective than one-level hedging algorithms, and three levels are not better than two levels.
bouzy11.pdf (134.66 Ko) Télécharger le fichier
hal-00975943 , version 1 (09-04-2014)
  • HAL Id : hal-00975943 , version 1
Bruno Bouzy, Marc Métivier, Damien Pellier. Hedging Algorithms and Repeated Matrix Games. Workshop on Machine Learning and Data Mining in and around Games (ECML-PKDD), Sep 2011, Athens, Greece. ⟨hal-00975943⟩
Collections
LIPADE UP-SCIENCES
152 Consultations
128 Téléchargements
