Overview of Distributed Linear Algebra on Hybrid Nodes over the StarPU Runtime
Runtime systems usually abstract a single node, like Plasma/Quark, Flame/SuperMatrix, Morse/StarPU,Dplasma/Parsec ... When going into harnessing cluster of nodes, how should they communicate? By using explicit MPI user calls ? By using a specific paradigm (Dplasma) ? Or can we keep the same paradigm and almost the same code, and leave the runtime system handle data transfers? We show how such a system has been sucessfully implemented on top of the StarPU runtime.
