Coupon collecting and transversals of hypergraphs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Mathematics and Theoretical Computer Science Année : 2013
The classic Coupon-Collector Problem (CCP) is generalized. Only basic probability theory is used. Centerpiece rather is an algorithm that efficiently counts all k-element transversals of a set system.
2331-8318-2-PB.pdf (333.77 Ko) Télécharger le fichier
hal-00980772 , version 1 (18-04-2014)
Marcel Wild, Svante Janson, Stephan Wagner, Dirk Laurie. Coupon collecting and transversals of hypergraphs. Discrete Mathematics and Theoretical Computer Science, 2013, Vol. 15 no. 2 (2), pp.259--270. ⟨10.46298/dmtcs.608⟩. ⟨hal-00980772⟩
Collections
TDS-MACS
130 Consultations
1099 Téléchargements
