Non-stationary elastic wavefields from an apodized normal transducer. Near-field asymptotics and numerics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Acta Acustica united with Acustica Année : 2005
We simulate non-stationary radiating near-field of a normal transducer acting at the surface of an isotropic homogeneous elastic half-space. The transducer is assumed large compared to the characteristic wavelength. Effects of non-constance of distribution of pressure over the aperture of the transducer on the wavefield are considered in detail. These are i) excitation of a plane S-wave, ii) anomalous polarization in the plane P-wave, and iii) suppression of edge waves by an apodization of the pressure distribution. Asymptotic formulas are tested against a numerical method based on new mixed finite elements. The agreement is found excellent within the bounds of the asymptotic theory.
Fichier non déposé
hal-00982677 , version 1 (24-04-2014)
  • HAL Id : hal-00982677 , version 1
Eliane Bécache, Aleksei Kiselev. Non-stationary elastic wavefields from an apodized normal transducer. Near-field asymptotics and numerics. Acta Acustica united with Acustica, 2005, 91 (5), pp.822-830. ⟨hal-00982677⟩
121 Consultations
0 Téléchargements
