Independent sets in (P₆, diamond)-free graphs
We prove that on the class of (P6,diamond)-free graphs the Maximum-Weight Independent Set problem and the Minimum-Weight Independent Dominating Set problem can be solved in polynomial time.
Mathématique discrète [cs.DM]
