Independent sets in (P₆, diamond)-free graphs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Mathematics and Theoretical Computer Science Année : 2009
We prove that on the class of (P6,diamond)-free graphs the Maximum-Weight Independent Set problem and the Minimum-Weight Independent Dominating Set problem can be solved in polynomial time.
509-4151-2-PB.pdf (175.36 Ko) Télécharger le fichier
hal-00988179 , version 1 (07-05-2014)
Raffaele Mosca. Independent sets in (P₆, diamond)-free graphs. Discrete Mathematics and Theoretical Computer Science, 2009, Vol. 11 no. 1 (1), pp.125--140. ⟨10.46298/dmtcs.473⟩. ⟨hal-00988179⟩
Collections
TDS-MACS
131 Consultations
948 Téléchargements
