Asymptotic enumeration on self-similar graphs with two boundary vertices - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Mathematics and Theoretical Computer Science Année : 2009
We study two graph parameters, namely the number of spanning forests and the number of connected subgraphs, for self-similar graphs with exactly two boundary vertices. In both cases, we determine the general behavior for these and related auxiliary quantities by means of polynomial recurrences and a careful asymptotic analysis. It turns out that the so-called resistance scaling factor of a graph plays an essential role in both instances, a phenomenon that was previously observed for the number of spanning trees. Several explicit examples show that our findings are likely to hold in an even more general setting.
969-4053-1-PB.pdf (203.21 Ko) Télécharger le fichier
hal-00988183 , version 1 (07-05-2014)
Elmar Teufl, Stephan Wagner. Asymptotic enumeration on self-similar graphs with two boundary vertices. Discrete Mathematics and Theoretical Computer Science, 2009, Vol. 11 no. 1 (1), pp.11--31. ⟨10.46298/dmtcs.471⟩. ⟨hal-00988183⟩
Collections
TDS-MACS
85 Consultations
840 Téléchargements
