String pattern avoidance in generalized non-crossing trees - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Mathematics and Theoretical Computer Science Année : 2009
The problem of string pattern avoidance in generalized non-crossing trees is studied. The generating functions for generalized non-crossing trees avoiding string patterns of length one and two are obtained. The Lagrange inversion formula is used to obtain the explicit formulas for some special cases. A bijection is also established between generalized non-crossing trees with special string pattern avoidance and little Schr ̈oder paths.
957-4101-2-PB.pdf (117.4 Ko) Télécharger le fichier
hal-00988187 , version 1 (07-05-2014)
Yidong Sun, Zhiping Wang. String pattern avoidance in generalized non-crossing trees. Discrete Mathematics and Theoretical Computer Science, 2009, Vol. 11 no. 1 (1), pp.79--93. ⟨10.46298/dmtcs.465⟩. ⟨hal-00988187⟩
Collections
TDS-MACS
56 Consultations
803 Téléchargements
