Gray codes avoiding matchings - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Mathematics and Theoretical Computer Science Année : 2009
A (cyclic) n-bit Gray code is a (cyclic) ordering of all 2(n) binary strings of length n such that consecutive strings differ in a single bit. Equivalently, an n-bit Gray code can be viewed as a Hamiltonian path of the n-dimensional hypercube Q(n), and a cyclic Gray code as a Hamiltonian cycle of Q(n). In this paper we study (cyclic) Gray codes avoiding a given set of faulty edges that form a matching. Given a matching M and two vertices u, v of Q(n), n >= 4, our main result provides a necessary and sufficient condition, expressed in terms of forbidden configurations for M, for the existence of a Gray code between u and v that avoids M. As a corollary. we obtain a similar characterization for a cyclic Gray code avoiding M. In particular, in the case that M is a perfect matching, Q(n) has a (cyclic) Gray code that avoids M if and only if Q(n) - M is a connected graph. This complements a recent result of Fink, who proved that every perfect matching of Q(n) can be extended to a Hamiltonian cycle. Furthermore, our results imply that the problem of Hamilionicity of Q(n) with faulty edges, which is NP-complete in general, becomes polynomial for up to 2(n-1) edges provided they form a matching.
1310-4767-1-PB.pdf (351.68 Ko) Télécharger le fichier
hal-00988206 , version 1 (07-05-2014)
Darko Dimitrov, Tomáš Dvořák, Petr Gregor, Riste Škrekovski. Gray codes avoiding matchings. Discrete Mathematics and Theoretical Computer Science, 2009, Vol. 11 no. 2 (2), pp.123--147. ⟨10.46298/dmtcs.457⟩. ⟨hal-00988206⟩
Collections
TDS-MACS
111 Consultations
981 Téléchargements
