Diffraction by an acoustic grating perturbed by a bounded obstacle - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Advances in Computational Mathematics Année : 2002
Karim Ramdani
An original approach to solve 2D time harmonic diffraction problems involving locally perturbed gratings is proposed. The propagation medium is composed of a periodically stratified half-space and a homogeneous half-space containing a bounded obstacle. Using Fourier and Floquet transforms and integral representations, the diffraction problem is formulated as a coupled problem of Fredholm type with two unknowns: the trace of the diffracted field on the interface separating the two half-spaces on one hand, and the restriction of the diffracted field to a bounded domain surrounding the obstacle, on the other hand.
hal-00990202 , version 1 (13-05-2014)
Anne-Sophie Bonnet-Ben Dhia, Karim Ramdani. Diffraction by an acoustic grating perturbed by a bounded obstacle. Advances in Computational Mathematics, 2002, 16 (2-3), pp.113-138. ⟨10.1023/A:1014437813575⟩. ⟨hal-00990202⟩
102 Consultations
0 Téléchargements
