A non elliptic spectral problem related to the analysis of superconductive micro-strip lines - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ESAIM: Mathematical Modelling and Numerical Analysis Année : 2002
Karim Ramdani
This paper is devoted to the spectral analysis of a non elliptic operator A , deriving from the study of superconducting micro-strip lines. Once a sufficient condition for the self-adjointness of operator A has been derived, we determine its continuous spectrum. Then, we show that A is unbounded from below and that it has a sequence of negative eigenvalues tending to -∞. Using the Min-Max principle, a characterization of its positive eigenvalues is given. Thanks to this characterization, some conditions on the geometrical (large width) and physical (large dielectric permittivity in modulus) properties of the strip that ensure the existence of positive eigenvalues are derived. Finally, we analyze the asymptotic behavior of the eigenvalues of A as the dielectric permittivity of the strip goes to -∞.
02_M2AN.pdf (466.55 Ko) Télécharger le fichier
hal-00990209 , version 1 (14-02-2017)
Anne-Sophie Bonnet-Ben Dhia, Karim Ramdani. A non elliptic spectral problem related to the analysis of superconductive micro-strip lines. ESAIM: Mathematical Modelling and Numerical Analysis, 2002, 36 (3), pp.461-487. ⟨10.1051/m2an:2002021⟩. ⟨hal-00990209⟩
179 Consultations
102 Téléchargements
