Distributional Analysis of the Parking Problem and Robin Hood Linear Probing Hashing with Buckets
This paper presents the first distributional analysis of both, a parking problem and a linear probing hashing scheme with buckets of size b. The exact distribution of the cost of successful searches for a b alpha-full table is obtained, and moments and asymptotic results are derived. With the use of the Poisson transform distributional results are also obtained for tables of size m and n elements. A key element in the analysis is the use of a new family of numbers, called Tuba Numbers, that satisfies a recurrence resembling that of the Bernoulli numbers. These numbers may prove helpful in studying recurrences involving truncated generating functions, as well as in other problems related with buckets.
Domains
Discrete Mathematics [cs.DM]
