On the metric dimension of Grassmann graphs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Mathematics and Theoretical Computer Science Année : 2012
The metric dimension of a graph Gamma is the least number of vertices in a set with the property that the list of distances from any vertex to those in the set uniquely identifies that vertex. We consider the Grassmann graph G(q)(n, k) (whose vertices are the k-subspaces of F-q(n), and are adjacent if they intersect in a (k 1)-subspace) for k \textgreater= 2. We find an upper bound on its metric dimension, which is equal to the number of 1-dimensional subspaces of F-q(n). We also give a construction of a resolving set of this size in the case where k + 1 divides n, and a related construction in other cases.
2049-6715-1-PB.pdf (260.07 Ko) Télécharger le fichier
hal-00990476 , version 1 (13-05-2014)
Robert F. Bailey, Karen Meagher. On the metric dimension of Grassmann graphs. Discrete Mathematics and Theoretical Computer Science, 2012, Vol. 13 no. 4 (4), pp.97--104. ⟨10.46298/dmtcs.532⟩. ⟨hal-00990476⟩
Collections
TDS-MACS
46 Consultations
1248 Téléchargements
