Separating the k-party communication complexity hierarchy: an application of the Zarankiewicz problem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Mathematics and Theoretical Computer Science Année : 2011
For every positive integer k, we construct an explicit family of functions f : \0, 1\(n) -\textgreater \0, 1\ which has (k + 1) - party communication complexity O(k) under every partition of the input bits into k + 1 parts of equal size, and k-party communication complexity Omega (n/k(4)2(k)) under every partition of the input bits into k parts. This improves an earlier hierarchy theorem due to V. Grolmusz. Our construction relies on known explicit constructions for a famous open problem of K. Zarankiewicz, namely, to find the maximum number of edges in a graph on n vertices that does not contain K-s,K-t as a subgraph.
2048-6587-1-PB.pdf (290.56 Ko) Télécharger le fichier
hal-00990498 , version 1 (13-05-2014)
Thomas P. Hayes. Separating the k-party communication complexity hierarchy: an application of the Zarankiewicz problem. Discrete Mathematics and Theoretical Computer Science, 2011, Vol. 13 no. 4 (4), pp.15--22. ⟨10.46298/dmtcs.546⟩. ⟨hal-00990498⟩
Collections
TDS-MACS
43 Consultations
785 Téléchargements
