Sturmian Sequences and Invertible Substitutions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Mathematics and Theoretical Computer Science Année : 2011
It is known that a Sturmian sequence S can be defined as a coding of the orbit of rho (called the intercept of S) under a rotation of irrational angle alpha (called the slope). On the other hand, a fixed point of an invertible substitution is Sturmian. Naturally, there are two interrelated questions: (1) Given an invertible substitution, we know that its fixed point is Sturmian. What is the slope and intercept? (2) Which kind of Sturmian sequences can be fixed by certain non-trivial invertible substitutions? In this paper we give a unified treatment to the two questions. We remark that though the results are known, our proof is very elementary and concise.
1486-6349-2-PB.pdf (214.19 Ko) Télécharger le fichier
hal-00990499 , version 1 (13-05-2014)
Li Peng, Bo Tan. Sturmian Sequences and Invertible Substitutions. Discrete Mathematics and Theoretical Computer Science, 2011, Vol. 13 no. 2 (2), pp.63--68. ⟨10.46298/dmtcs.554⟩. ⟨hal-00990499⟩
Collections
TDS-MACS
47 Consultations
935 Téléchargements
