Avoidance colourings for small nonclassical Ramsey numbers
The irredundant Ramsey number s - s(m, n) [upper domination Ramsey number u - u(m, n), respectively] is the smallest natural number s [u, respectively] such that in any red-blue edge colouring (R, B) of the complete graph of order s [u, respectively], it holds that IR(B) \textgreater= m or IR(R) \textgreater= n [Gamma (B) \textgreater= m or Gamma(R) \textgreater= n, respectively], where Gamma and IR denote respectively the upper domination number and the irredundance number of a graph. Furthermore, the mixed irredundant Ramsey number t = t(m, n) [mixed domination Ramsey number v = v(m, n), respectively] is the smallest natural number t [v, respectively] such that in any red-blue edge colouring (R, B) of the complete graph of order t [v, respectively], it holds that IR(B) \textgreater= m or beta(R) \textgreater= n [Gamma(B) \textgreater= m or beta(R) \textgreater= n, respectively], where beta denotes the independent domination number of a graph. These four classes of non-classical Ramsey numbers have previously been studied in the literature. In this paper we introduce a new Ramsey number w = w(m, n), called the irredundant-domination Ramsey number, which is the smallest natural number w such that in any red-blue edge colouring (R, B) of the complete graph of order w, it holds that IR(B) \textgreater= m or Gamma(R) \textgreater= n. A computer search is employed to determine complete sets of avoidance colourings of small order for these five classes of nonclassical Ramsey numbers. In the process the fifteen previously unknown Ramsey numbers t(4, 4) = 14, t(6, 3) = 17, u(4, 4) = 13, v(4, 3) = 8, v(4, 4) = 14, v(5, 3) = 13, v(6, 3) = 17, w(3, 3) = 6, w(3, 4) = w(4, 3) = 8, w(4, 4) = 13, w(3, 5) = w(5, 3) = 12 and w(3, 6) = w(6, 3) = 15 are established.
Mathématique discrète [cs.DM]
