On the existence of telescopers for mixed hypergeometric terms - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Symbolic Computation Année : 2014
We present a criterion for the existence of telescopers for mixed hypergeometric terms, which is based on additive and multiplicative decompositions. The criterion enables us to determine the termination of Zeilberger's algorithms for mixed hypergeometric inputs, and to verify that certain indefinite sums do not satisfy any polynomial differential equation.
criteria.pdf (356.04 Ko) Télécharger le fichier
hal-00991211 , version 1 (14-05-2014)
  • HAL Id : hal-00991211 , version 1
Shaoshi Chen, Frédéric Chyzak, Ruyong Feng, Guofeng Fu, Ziming Li. On the existence of telescopers for mixed hypergeometric terms. Journal of Symbolic Computation, 2014. ⟨hal-00991211⟩
Collections
INRIA INRIA2
147 Consultations
171 Téléchargements
