Asymptotic analysis of a Neumann problem in a domain with cusp. Application to the collision problem of rigid bodies in a perfect fluid. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2014
We study a two dimensional collision problem for a rigid solid immersed in a cavity filled with a perfect fluid. We are led to investigate the asymptotic behavior of the Dirichlet energy associated to the solution of a Laplace Neumann problem as the distance $\varepsilon>0$ between the solid and the cavity's bottom tends to zero. Denoting by $\alpha>0$ the tangency exponent at the contact point, we prove that the solid always reaches the cavity in finite time, but with a non zero velocity for $\alpha <2$ (real shock case), and with null velocity for $\alpha \geqslant 2$ (smooth landing case). Our proof is based on a suitable change of variables sending to infinity the cusp singularity at the contact. More precisely, for every $\varepsilon\geqslant 0$, we transform the Laplace Neumann problem into a generalized Neumann problem set on a domain containing a horizontal strip $]0,\ell_\varepsilon[\times ]0,1[$, where $\ell_\varepsilon\to +\infty$.
contact_hal_140522.pdf (402.66 Ko) Télécharger le fichier
hal-00994433 , version 1 (21-05-2014)
hal-00994433 , version 2 (26-09-2015)
hal-00994433 , version 3 (12-01-2016)
Alexandre Munnier, Karim Ramdani. Asymptotic analysis of a Neumann problem in a domain with cusp. Application to the collision problem of rigid bodies in a perfect fluid.. 2014. ⟨hal-00994433v1⟩
345 Consultations
361 Téléchargements
