Non Unitary Random Walks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Mathematics and Theoretical Computer Science Année : 2009
Philippe Jacquet
Motivated by the recent refutation of information loss paradox in black hole by Hawking, we investigate the new concept of {\it non unitary random walks}. In a non unitary random walk, we consider that the state 0, called the {\it black hole}, has a probability weight that decays exponentially in $e^{-\lambda t}$ for some $\lambda>0$. This decaying probabilities affect the probability weight of the other states, so that the the apparent transition probabilities are affected by a repulsion factor that depends on the factors $\lambda$ and black hole lifetime $t$. If $\lambda$ is large enough, then the resulting transition probabilities correspond to a neutral random walk. We generalize to {\it non unitary gravitational walks} where the transition probabilities are function of the distance to the black hole. We show the surprising result that the black hole remains attractive below a certain distance and becomes repulsive with an exactly reversed random walk beyond this distance. This effect has interesting analogy with so-called dark energy effect in astrophysics.
1349-5118-2-PB.pdf (599.29 Ko) Télécharger le fichier
hal-00994977 , version 1 (22-05-2014)
Philippe Jacquet. Non Unitary Random Walks. Discrete Mathematics and Theoretical Computer Science, 2009, Vol. 12 no. 2 (2), pp.333-362. ⟨10.46298/dmtcs.480⟩. ⟨hal-00994977⟩
310 Consultations
810 Téléchargements
