6-DoF automatic micropositioning using photometric information
In this paper, an approach for 6-DoF automatic micropositioning is presented. It involves a closed-loop visual servoing scheme in order to achieve eye-to-hand positioning task in micro-scale. Instead of using classical visual features in the servoing scheme, pure image photometric information from the vision sensor is employed to compute the control law for micropositioning. The approach is validated in simulation as well as experimentally on a parallel positioning stage and a digital microscope at low magnification. Experimental results show the accuracy and efficiency of this control scheme.
Robotique [cs.RO]
