Assessment of turbulence closures for detached flows control - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this study, di fferent turbulence closures are compared for the prediction of detached flows over a backward facing step, including a flow control device based on oscillatory suction and blowing. An automated optimization of the control parameters (frequency and amplitude) is carried out for the di fferent closures, to assess the ability of Reynolds-Averaged Navier-Stokes (RANS) models to predict similar optimal parameters.
wccm2014.pdf (818.32 Ko) Télécharger le fichier
hal-00998600 , version 1 (02-06-2014)
  • HAL Id : hal-00998600 , version 1
Jérémie Labroquère, Régis Duvigneau, Emmanuel Guilmineau. Assessment of turbulence closures for detached flows control. 6th ECCOMAS Computational Fluid Dynamics Conference, Jul 2014, Barcelona, Spain. ⟨hal-00998600⟩
249 Consultations
203 Téléchargements
