SINR in cellular networks and the two-parameter Poisson-Dirichlet process - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2014
Stochastic geometry models of wireless networks based on Poisson point processes are increasingly being developed with a focus on studying various signal-to-interference-plus-noise ratio (SINR) values. We show that the SINR values experienced by a typical user with respect to different base stations of a Poissonian cellular network are related to a specific instance of the so-called two-parameter Poisson-Dirichlet process. This process has many interesting properties as well as applications in various fields. We give examples of several results proved for this process that are of immediate or potential interest in the development of analytic tools for cellular networks. Some of them simplify or are reminiscent of certain results that are recently being developed in wireless networks literature. By doing this we hope to motivate further research and use of Poisson-Dirichlet processes in this new setting.
SINRLetter04.pdf (138.61 Ko) Télécharger le fichier
hal-01002977 , version 1 (07-06-2014)
hal-01002977 , version 2 (10-06-2014)
hal-01002977 , version 3 (23-06-2014)
hal-01002977 , version 4 (24-06-2014)
hal-01002977 , version 5 (02-08-2014)
Holger Paul Keeler, Bartlomiej Blaszczyszyn. SINR in cellular networks and the two-parameter Poisson-Dirichlet process. 2014. ⟨hal-01002977v1⟩
466 Consultations
382 Téléchargements
