Simulating Diffusion Processes in Discontinuous Media: Benchmark Tests - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Computational Physics Année : 2016
We present several benchmark tests for Monte Carlo methods simulating diffusion in one-dimensional discontinuous media. These benchmark tests aim at studying the potential bias of the schemes and their impact on the estimation of micro- or macroscopic quantities (repartition of masses, fluxes, mean residence time,...). These benchmark tests are backed by a statistical analysis to filter out the bias from the unavoidable Monte Carlo error. We apply them on four different algorithms. The results of the numerical tests give a valuable insight of the fine behavior of these schemes, as well as rules to choose between them.
benchmarks_lejay_pichot_FV.pdf (1.59 Mo) Télécharger le fichier
benchmark_supplementary_material.pdf (419.46 Ko) Télécharger le fichier
hal-01003853 , version 1 (10-06-2014)
hal-01003853 , version 2 (23-02-2016)
hal-01003853 , version 3 (18-03-2016)
hal-01003853 , version 4 (05-07-2017)
Antoine Lejay, Géraldine Pichot. Simulating Diffusion Processes in Discontinuous Media: Benchmark Tests. Journal of Computational Physics, 2016, 314, pp.348-413. ⟨10.1016/j.jcp.2016.03.003⟩. ⟨hal-01003853v3⟩
643 Consultations
583 Téléchargements
