The Gudhi Library: Simplicial Complexes and Persistent Homology - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2014
Clément Maria
  • Fonction : Auteur correspondant
  • PersonId : 926304
  • IdHAL : cmaria
Connectez-vous pour contacter l'auteur
Jean-Daniel Boissonnat
  • Fonction : Auteur
  • PersonId : 935453
Marc Glisse
Mariette Yvinec
We present the main algorithmic and design choices that have been made to represent complexes and compute persistent homology in the Gudhi library. The Gudhi library (Geometric Understanding in Higher Dimensions) is a generic C++ library for computational topology. Its goal is to provide robust, efficient, flexible and easy to use implementations of state-of-the-art algorithms and data structures for computational topology. We present the different components of the software, their interaction and the user interface. We justify the algorithmic and design decisions made in Gudhi and provide benchmarks for the code. The software, which has been developed by the first author, is available at: project.inria.fr/gudhi/software/
gudhi.pdf (138.98 Ko) Télécharger le fichier
hal-01005601 , version 1 (12-06-2014)
hal-01005601 , version 2 (17-06-2014)
  • HAL Id : hal-01005601 , version 1
Clément Maria, Jean-Daniel Boissonnat, Marc Glisse, Mariette Yvinec. The Gudhi Library: Simplicial Complexes and Persistent Homology. 2014. ⟨hal-01005601v1⟩
539 Consultations
2961 Téléchargements
