A singular field method for the solution of Maxwell's equations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIAM Journal on Applied Mathematics Année : 1999
It is well known that in the case of a regular domain the solution of the time-harmonic Maxwell's equations allows a discretization by means of nodal finite elements: this is achieved by solving a regularized problem similar to the vector Helmholtz equation. The present paper deals with the same problem in the case of a nonconvex polyhedron. It is shown that a nodal finite element method does not approximate in general the solution to Maxwell's equations, but actually the solution to a neighboring variational problem involving a different function space. Indeed, the solution to Maxwell's equations presents singularities near the edges and corners of the domain that cannot be approximated by Lagrange finite elements. A new method is proposed involving the decomposition of the solution field into a regular part that can be treated numerically by nodal finite elements and a singular part that has to be taken into account explicitly. This singular field method is presented in various situations such as electric and magnetic boundary conditions, inhomogeneous media, and regions with screens. Copyright © 1999 Society for Industrial and Applied Mathematics
Fichier non déposé
hal-01009853 , version 1 (18-06-2014)
Anne-Sophie Bonnet-Ben Dhia, Christophe Hazard, Stéphanie Lohrengel. A singular field method for the solution of Maxwell's equations. SIAM Journal on Applied Mathematics, 1999, 59 (6), pp.2028-2044. ⟨10.1137/S0036139997323383⟩. ⟨hal-01009853⟩
190 Consultations
0 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
