ALTA: A BRDF analysis library - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this document, we introduce ALTA, a cross platform generic open-source library for Bidirectional Reflectance Distribution Function (BRDF) analysis. Among others, ALTA permits to estimate BRDF models parameters from measured data, to perform statistical analysis and also to export BRDF data models in a wide variety of formats.
egsr.pdf (872.36 Ko) Télécharger le fichier
presentation.pdf (7.52 Mo) Télécharger le fichier
Format : Figure, Image
Format : Autre
hal-01016531 , version 1 (30-06-2014)
hal-01016531 , version 2 (02-07-2014)
  • HAL Id : hal-01016531 , version 1
Laurent Belcour, Pascal Barla, Romain Pacanowski. ALTA: A BRDF analysis library. EGSR Workshop on Material Appearance Modeling, Jun 2014, Lyon, France. ⟨hal-01016531v1⟩
1574 Consultations
2047 Téléchargements
